QOS police issue
Aug 16th, 2009
I have a star network with multiple l2l tunnels. I am trying to give priority to RDP (3389) traffic. The following is my config that I am trying to use:
hostname(config)#class-map RDP_Pri
hostname(config-cmap)#description "This class-map matches all RDP traffic for 1XX.XXX.XXX.XXX 1"
hostname(config-cmap)#match port tcp eq 3389
hostname(config-cmap)#match tunnel-group 1XX.XXX.XXX.XXX
hostname(config-cmap)#class-map RDP_BestEffort
hostname(config-cmap)#description "This class-map matches all best-effort traffic for 1XX.XXX.XXX.XXX"
hostname(config-cmap)#match flow ip destination-address
hostname(config-cmap)#policy-map QOS
hostname(config-pmap)#class RDP_Pri
hostname(config-pmap-c)#priority
hostname(config-pmap-c)#class RDP_BestEffort
hostname(config-pmap-c)#police output 200000 37500
hostname(config-pmap-c)#class class-default
hostname(config-pmap-c)#police output 1000000 37500
hostname(config-pmap-c)#service-policy QOS interface outside
hostname(config)#priority-queue outside
hostname(config-priority-queue)#queue-limit 2048
hostname(config-priority-queue)#tx-ring-limit 256
When I get to the command:
I get the following error message:
ERROR: Must deconfigure priority in this class before issuing this command
ERROR: tunnel-group can only be policed on a flow basis
Questions:
1. Why do I need to deconfigure priority? How would I do this?
2. Other than the errors, does this config look good? Can it be made better?
Thanks in advance
