Mars in existing topology
Aug 17th, 2009
Hello, I'm implementing MARS in my network. I have a 6500 switch for a core switch and 3560 for access switches. I use a FWSM with vlan interfaces. All vlans in my network use the FWSM as a layer 3 termination point.
I want to send netflow information to the MARS. However all interfaces on my switches are layer 2 and netflow is enabled on layer 3 interfaces. My FWSM does not support netflow for this. How and where can I use netflow to send to my MARS. Is there another way to implement MARS in my network. May be SNMP and where should i use this
Overall Rating: 4 (1 ratings)
patwill66_2 Mon, 08/17/2009 - 05:15
I use mls netflow to accomplish what you are trying to do. Here are the commands I used to do it and the Cisco guide I initially found.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080721701.shtml
ip flow ingress layer2-switched vlan XX,XX-XX,XX-XX,XX
mls ip slb purge global
mls aging long 300
mls aging normal 60
mls netflow interface
mls flow ip interface-full
no mls flow ipv6
mls nde sender version 5
mls cef error action reset
ip flow-export source vlanXX
ip flow-export version 5
ip flow-export destination x.x.x.x 2055
Dirks Wed, 08/19/2009 - 05:27
Thank you very much for your help. I did what you suggested and now it seems to work fine.
