Gatekeeper Registartion Problem
Aug 17th, 2009
I have an IPT deployment in 33 sites using one gatekeeper in the Head officeCisco 2811). The system worked well timm today when none of the remote gateways are able to register with the central gatekeeper. debug h225 asn1 reveals no rejection codes.
Please needs someones help to where else i should check.
Tommer Catlin Wed, 08/19/2009 - 07:12
  • Green, 3000 points or more
Since none of the gateways have registered, Id a shut gatekeeper and then a no shut to see if they register.
It's a little odd all of the gateways unregistered from the gk
andres.pasten Wed, 08/19/2009 - 07:22
Have you tried on gateways configuring no gateway and then gateway, and look what appear on debugs?
Andres
