Warning message
HSRP configuration in different domain
Answered Question
Aug 17th, 2009
Hello Everybody
I have two datacenter called DC1 & DC2 each DC has two core switch CO1 primary and CO2 secondary.
Both DCs are different VTP domains. HSRP configured for DATA and VOICE VLANS for redundancy if any CORE down another one will take care of it. For users DATA and VOICE I didn't face any problem in both DC access locations because they are same VLAN but different IP segment. I have two CCM servers for VOICE, now both are in DC1 the servers are in VLAN 185 I configured HSRP in DC1 core locations as follows
CORE-1
description ITD-ITD112G-DATA11
ip address 10.1.185.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip igmp version 3
standby 11 ip 10.1.185.1
standby 11 timers msec 250 msec 750
standby 11 priority 150
standby 11 preempt delay minimum 180
standby 11 authentication DES3auth
end
CORE-2
ip address 10.1.185.3 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip igmp version 3
end
I want to move one CCM to DC2 so before move the CCM server I tried to configure HSRP for the CCM VLAN 185 in DC2 as follows
CORE-1
ip address 10.1.185.4 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip igmp version 3
standby 11 priority 110
end
CORE-2
ip address 10.1.185.5 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip igmp version 3
end
After I configured HSRP the users in DC2 location IP phones are disconnected from CCM (both are in DC1) If I shut the interface VLAN 185 the users IP phones are working fine.
Please advice me how to configure HSRP in different VTP domains.
Correct Answer by Giuseppe Larosa about 8 years 5 days ago
Hello Shahul,
the problem is not related to the fact that there are two different VTP domains involved.
if DC1 to DC2 connectivity is layer3 based when you add vlan185 in DC2 with same ip subnet you are creating a duplicated subnet.
You should use the clustering over the WAN option that allows to have servers in different ip subnets if one waydelay is less then 20 ms.
So you can use a different ip subnet in DC2 and you need to add the moved server as a new subscriber.
if you have fast links like GE links and the two sites are not far (few hundreds km apart is supported) this clustering over WAN can work well.
You need also to use QoS to protect inter-cluster traffic.
Hope to help
Giuseppe
Overall Rating: 1 (1 ratings)
Correct Answer
Giuseppe Larosa Mon, 08/17/2009 - 04:27
  • Hall of Fame,
    Founding Member
Hello Shahul,
Hope to help
Giuseppe
