outbound voice call loadbalancing on multiple PRI
Answered Question
Aug 17th, 2009
Pls help i am currently having three PRI in h.323 setup on single gateway and CUCM 6.1.How can i loadbalance oubound voice calls on all the three PRI.If any sample config available pls share.
Correct Answer by Jaime Valencia about 7 years 8 months ago
Configure a route group with Distribution Algorithm = Circular
java
if this helps, please rate
Overall Rating: 5 (2 ratings)
paolo bevilacqua Mon, 08/17/2009 - 04:23
  • Hall of Fame,
    Founding Member
Under controller, put them in a trunk group with a name of your choice.
Reference said trunk group under pots DP instead of port.
You can also configure hunt schemes under trunk group configuration mode.
paolo bevilacqua Mon, 08/17/2009 - 07:29
  • Hall of Fame,
    Founding Member
You are welcome, please remember to rate useful posts with the scrollbox below.
ajay-pawar Mon, 08/17/2009 - 05:37
Hi can u pls suggest in case of MGCP how we can configure it on CUCM..
Correct Answer
Jaime Valencia Mon, 08/17/2009 - 05:40
  • Cisco Employee,
  • Hall of Fame,
    2011
java
ajay-pawar Thu, 08/20/2009 - 21:52
Thanks for the solution.I am facing another problem pls help .
How to configure load balacing with CUCM in gateway.
For example: Suppose I have dial-pattern x.x.x.x and three CallManager Pub,sub1 & sub2 in this case I have to configure preference in each dial-peer to select the
CallManager for incoming calls from PSTN on gateway.
In above configuration next CallManger is used only when first CallManager is not available.
Is there any way to configure so that first incoming call will go to first CUCM,2nd call will go to 2nd CUCM and so on
