LANtoLAN IPSec + PBR + DVTI
Aug 17th, 2009
I need to clarify some things about routing with DVTI on the Cisco 1801. I have a VirtualTemplate interface associated with a Dialer interface:
interface Virtual-Template1 type tunnel
ip unnumbered Dialer0
tunnel source Dialer0
tunnel mode ipsec ipv4
tunnel protection ipsec profile VTI_Profile
crypto isakmp profile VTI_Profile
keyring TEST
match identity address 1.2.3.4 255.255.255.255
client configuration address respond
keepalive 3600 retry 60
virtual-template 1
local-address Dialer0
Gateway of last resort is not set. I have PBR for incoming IPSec connections:
ip local policy route-map LOCAL
route-map LOCAL permit 10
match ip address 150
set interface Dialer0
route-map LOCAL permit 20
match ip address 152
set global
access-list 150 permit ip host 5.6.7.8 any
access-list 152 permit ip any any
After IPSec tunnel is established the new interface VirtualAccess1 is appeared and route to remote LAN added to global route table:
S 192.168.40.0/24 [1/0] via 1.2.3.4, Virtual-Access1
The ping from local LAN to remote LAN is not working until I add the default gateway. Is there route lookup action after packets pass through VirtualAccess interface?
Overall Rating: 1 (1 ratings)
aleksei.timofeyev Tue, 08/25/2009 - 20:00
Could you look at Figure 3 at URL specified by you? If I configure different PBRs for inside interface,outside interface and VTI in what sequence they will be looked up?
regards,
Aleksei
