Cisco VPN Client 5.x
Aug 17th, 2009
We have some Toshiba R200 Laptops that when trying to install version 5.x of the VPN client , the network adapter gets trashed.
To fix we have to uninstall the client , delete all the network driver's , reboot and re install the drivers, we cannot install the vpn client at all.
Has anybody got any experience of this ?
Scott.
ivarnhagen Mon, 08/17/2009 - 05:19
Hi Scott,
I had some bad experience installing the Cisco VPN Client v5.0.05.0290 once (not on a Toshiba though)...afterwards I had to re-image the laptop. An older version of the client worked fine though.
Also remember in case youre installing on Vista: theres a Windows patch that needs to be installed first (Windows6.0-KB952876-x86.msu)
hth
Ingo
