MSC / PLIM power consumption
Using a single-shelf CRS-1 config I noticed the drop in power intake (monitored using clamp-on ammeters) when removing PLIMs being a lot higher than its maximum power consumption according to the data sheet. My only explanation would be that the mated MSCs are being shut off automatically at the same time. Given the MSCs specified power uptake of up to 375W that would explain power drops around 200...350W higher than specified for the PLIM alone. Can anyone confirm that theory or come up with other suggestions?
