Warning message
Cisco 2821 - E1 PRI and PVDM issue
Aug 17th, 2009
Hi all ;
I have problem with my router and E1 , whenever I dial E1 number it has mute call , router answer but there is no handshake sound , attach you may find configuration , please consider that this is really urgent for me to fix this issue .
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821 , VID: V03 , SN:
NAME: "36 port PVDMII digital modem on Slot 0 SubSlot 4", DESCR: "36 port PVDMII
digital modem"
PID: PVDM2-36DM , VID: V01 , SN:
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP S
IMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN:
NAME: "Two Port Channelized E1/T1/PRI with Integrated CSU on Slot 2", DESCR: "Tw
o Port Channelized E1/T1/PRI with Integrated CSU"
PID: , VID: 1.0, SN:
Overall Rating: 4 (1 ratings)
paolo bevilacqua Mon, 08/17/2009 - 09:59
  • Hall of Fame,
    Founding Member
First of all you should upgrade you IOS as you're still running the initial version of 12.4-9T, likely buggy.
Then, you should have clock source line and network-clock-participate and -select.
Also note, the PVDM2-64 for voice, will not work with the channelized PRI card for data. It works exclusively with cards that have V in the part number, likve VWIC.
Finally, please do not put time pressure for answers, as this is a free forum, not a paid for service.
