Cisco UCS - Syslog /Trap vs Event Subcription
Aug 17th, 2009
Cisco UCS allows for clients to subscribe for XML based events that can be used to receive configuration change information over http/https. Is the same/similar information available via Syslog messages or SNMP traps from UCS? If not, what information is available via the Syslog messages or Trap notifications ? Also is the Syslog or Snmp trap functionality supported in the Cisco UCSM simulators ?
ivillegas Fri, 08/21/2009 - 10:27
  • Silver, 250 points or more
You can set SNMP traps to monitor fans, power supplies, and temperature settings, or to test a call home application. Use the following commands to set SNMP traps:
test pfmtest-SNMP-trap fan
test pfmtest-SNMP-trap power supply
test pfmtest-SNMP-trap temp-sensor
SNMP Traps and Informs:
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/mib/reference/UCS_MIBRef.html#wp75887
Set up Syslog for Cisco UCS:
http://www.cisco.com/en/US/products/ps10281/products_configuration_example09186a0080ae0f24.shtml
