routers for CCVP practice
Wilson Samuel Tue, 08/18/2009 - 03:46
I dont think its practically feasible to have the configuration tested on anything less than 2800, also the commands are slightly different for the 2800 v/s 1700.
If I were you, I would have choosen the online Racks available for the CCIE-V which will definitly offer almost everything at a fraction of the costs eg ipexpert.com or ine.com
HTH,
Please rate if it helps
Wilson Samuel
yucelbasoglu Thu, 09/10/2009 - 23:03
you don't need a Hardware, You can do with VMware...
The Routers are more expensive, anyway The 2811 with NM-2V and VIC2-FXS and VIC2FXO are ideal hardware for Voice practice.
