issue with config
jlight80911
Hey guys i am back again for a little assistance.
keeping this brief
currently we have a dsl modem connecting to a linksys (p.o.s. router) then connecting to a dhcp server, which then hands out ip address's.
The linksys router is slowly dieing, and i purchased a cisco 1800 router.
The dsl modem has a built in router hands the linksys router 192.168.0.2. Our server 2008 hands out 172.16.1.0 ip's to the users.
my issues is figuring out how to configure the router with the default gateway. I want to keep all devices in place and use them as intended. not using the router for dhcp.
here is my config so far.
Current configuration : 1507 bytes
version 12.4
hostname qwest-net-rtr
boot-start-marker
boot-end-marker
enable secret 5 $1$.cce$PE0lB1rdESIZxgFuB8ODl0
enable password password1
no aaa new-model
clock timezone MTN -7
clock summer-time MDT recurring
ip cef
archive
log config
hidekeys
interface FastEthernet0/1/0
no cdp enable
interface FastEthernet0/1/1
no cdp enable
interface FastEthernet0/1/2
no cdp enable
interface FastEthernet0/1/3
no cdp enable
interface Cable-Modem0/0/0
no ip address
shutdown
no cdp enable
interface FastEthernet0/0
ip address 172.16.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
ip address 192.168.0.2 255.255.255.0
ip nat outside
duplex auto
speed auto
no cdp enable
interface Vlan1
no ip address
shutdown
no mop enabled
ip forward-protocol nd
ip http server
ip nat pool overload 192.168.0.10 192.168.0.10 prefix-length 24
ip nat inside source list 7 pool overload overload
access-list 7 permit 172.16.1.0 0.0.0.255
snmp-server community public RO
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password passwordv
login
scheduler allocate 20000 1000
no process cpu extended
no process cpu autoprofile hog
end
44 Replies 44
Jerry Ye
You can put the following configuration in, assuming your NAT is done correctly
ip routing
ip classless
ip route 0.0.0.0 0.0.0.0 f0/1
HTH,
jerry
tried that did not work. I am able to ping the web from the router, but not from my pc. from my pc i can ping the dsl modems default gateway, but can not get out past that.
any ideas?
Hi Jared,
Your NAT configuration needs to be changed along with the static routes I gave you before
no ip nat pool overload 192.168.0.10 192.168.0.10 prefix-length 24
no ip nat inside source list 7 pool overload overload
ip nat inside source list 7 interface FastEthernet0/1 overload
HTH,
jerry
Hey Jerry,
Here is the current config now.
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
archive
log config
hidekeys
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no ip address
shutdown
no cdp enable
no ip address
duplex auto
speed auto
no cdp enable
ip address 192.168.1.2 255.255.255.0
ip nat outside
duplex auto
speed auto
no cdp enable
interface Vlan1
ip address 172.16.2.1 255.255.255.0
ip nat inside
no mop enabled
ip http server
access-list 7 permit 172.16.2.0 0.0.0.255 log
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password passwordv
login
end
Yes i did change the IP's just so i can test this during the day with out putting a hault on employees. Currently it goes:
192.168.1.1 is my qwest dsl modem
192.168.1.2 is going to the wan port of cisco router
172.16.2.1 is the cisco router
172.16.2.45 is the lan ip from the cisco
we do have a DHCP Server that will be in production in time..
hopefully this helps you see what im trying to accomplish a little bit better.
At the moment, i can no longer access the dsl modem, i use to be able to get to the web gui, and ping 192.168.1.1. After using the command you gave me i can no longer do so. I also can not ping out to any web address's
any thoughts on this?
Jared
Hi Jared,
You have to put the default route in the config
ip routing
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
After you did that and can you test it and post the the following commands if it is still not working
show ip route
show ip nat translations
HTH,
jerry
Jerry,
Here are the results from what you have asked for
qwest-net-rtr(config)#do sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
172.16.0.0/24 is subnetted, 1 subnets
C 172.16.2.0 is directly connected, Vlan1
C 192.168.1.0/24 is directly connected, FastEthernet0/1
S* 0.0.0.0/0 is directly connected, FastEthernet0/1
qwest-net-rtr#sh ip nat trans
Pro Inside global Inside local Outside local Outside global
icmp 192.168.1.2:1 172.16.2.45:1 172.16.1.128:1 172.16.1.128:1
icmp 192.168.1.2:1 172.16.2.45:1 192.168.1.1:1 192.168.1.1:1
Thank you
Hi Jared,
Are you able to ping the DSL router? Or access the Internet. The output looks okay so far.
jerry
From my pc i can not ping 192.168.1.1 (DSL router), also I can not access the internet either. However i can ping the wan port of the cisco router 192.168.1.2
From the Cisco router i can ping 192.168.1.1, and i can ping the WAN ip address of the dsl router. But i can not ping anything further than the WAN IP, i.e. www.google.com.
Hi Jared,
Sounds like your DSL router doesn't have a return path back to your router. I am assuming you are ping www.google.com's IP address (64.233.169.104), not the DNS name.
jerry
yes, I am pinging it based off ip, nothing comes back.
Hi Jared,
Let's change the default route configuration and test this again.
no ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip route 0.0.0.0 0.0.0.0 192.168.1.1
jerry
Jerry,
Now from the router i can ping web address's, but i can not ping from my pc. So im thinking im missing a route now. Any suggestions?
here is the config
no aaa new-model
ip cef
no ip domain lookup
archive
log config
hidekeys
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no ip address
shutdown
no cdp enable
no ip address
ip nat outside
duplex auto
speed auto
no cdp enable
ip nat outside
duplex auto
speed auto
no cdp enable
interface Vlan1
ip nat inside
no mop enabled
ip http server
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password passwordv
login
end
Can you do the following on the router
clear ip nat translation *
show ip route
And can you post me the ipconfig /all from your pc?
jerry
Here is that information
qwest-net-rtr#clear ip nat translation *
qwest-net-rtr#show ip route
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.1.1
qwest-net-rtr#show ip nat translation
qwest-net-rtr#
also,
IPv4 Address.... 172.16.2.45
subnet...........255.255.255.0
mask.............172.16.2.1
dns servers..... 172.16.2.1
.................172.16.1.1
