Unable to delete menus in 6500
Aug 17th, 2009
Dear Friends,
I have configured some menu commands on a 6500 running 12.2(18)SXH33a and SUp720-3B.
However, if i want to delete the menu, it does not delete it.
Even if i say no menu <opsmenu>, it does not delete it. The command is accepted but the
menu is still there when you say sh run.
If i try it on another 6500 with ver 12.2(18)SXF, it works fine.
It also works fine on a 7609.
Has anyone come across this issue?
Thanks a lot
Gautam
Giuseppe Larosa Wed, 08/19/2009 - 21:12
Hello Gautam,
as you can guess you are probably hitting a bug.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.html#wp4613826
I tried to look at bug toolkit but I didn't find a match.
you may open a TAC service request and get their feedback on this.
Otherwise you need to use a procedure like password recovery to have the device to boot without reading the configuration during a maintanance window.
Hope to help
Giuseppe
