Quick VPN with WRV200
Aug 17th, 2009
I recently purchased this business class router for my home setup. i am using private class 192.168 static addresses on my machines, i disabled dhcp on the router. I have timewarner for the ISP which is turbo speed. I wanted to setup the vpn access so when i am at work i can access my resources at home. I installed quickvpn, setup a user name and password on the router. I have my outside wan address. I login no problem, the private ip address internal for my work is 10.200.xxx.xxx so i can login it says its connected all is good so far, i go to run and type in \\computername nothing comes up. 1st issue and the 2nd issue is that after i disconnected it the adpater here on my work pc is now all screwed up. it has a primary wins server address and a secondary wins, we do not use wins.. here is the command line:
C:\Documents and Settings\jadair>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : ixiajadairhd
Primary Dns Suffix . . . . . . . : ixiacom.com
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : ixiacom.com
ixiacom.com
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : ixiacom.com
Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet
for hp
Physical Address. . . . . . . . . : 00-10-18-0D-23-89
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 10.200.25.107
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.200.25.1
DHCP Server . . . . . . . . . . . : 10.200.2.8
DNS Servers . . . . . . . . . . . : 10.200.3.8
10.200.2.8
10.200.2.7
10.200.2.9
Primary WINS Server . . . . . . . : 10.200.3.8
Secondary WINS Server . . . . . . : 10.200.2.8
Lease Obtained. . . . . . . . . . : Monday, August 17, 2009 5:02:41 PM
Lease Expires . . . . . . . . . . : Monday, August 24, 2009 5:02:41 PM
PLEASE HELP
the issue is that when i open IE it does now go to my home page nor when i try to go to my homepage which is my help desk ticketing system it goes to some site outside when this is an internal website.
vmoopeung Fri, 08/21/2009 - 12:47
  • Bronze, 100 points or more
We need to determine first the network connection being used by the computer. If the client computer is behind a router, make sure that port 443 and 60443 is not being blocked because it is the port being use by the device.
1) Use the latest QuickVPN client software v 1.2.11
Refer to the below URL to verify your configuration:
http://www.cisco.com/en/US/products/ps9923/products_qanda_item09186a0080a348c6.shtml
