Multicast - Anycast w/ AutoRP design
Giuseppe Larosa Mon, 08/17/2009 - 19:24
  • Hall of Fame,
    Founding Member
Hello Alex,
anycast RP can be implemented also using BSR instead of autoRP this has some advantages:
BSR is standards based
BSR uses pim v2 bsr messages and doesn't need to use ip pim sparse-dense-mode allowing for better control
BSR provides an election mechanism for both the candidate RPs and the BSR routers providing redundancy.
Auto RP doesn't provide an election mechanism for the mapping agent
BSR messages are complete information and not the point of view of the mapping agent.
The hash function allows for forms of load balancing between two candidate RPs based on group ip addresses.
So if you have time I would test anycast RP with BSR.
The config examples are present in the document you have linked.
Hope to help
Giuseppe
Peter Paluch Tue, 08/18/2009 - 03:40
  • Cisco Employee,
Hi Alex,
Yes, the BSR and the PIM Sparse-Dense are fully interoperable. Do you have any particular need to run the hybrid Sparse-Dense mode?
Best regards,
Peter
