configuring dhcp pool with different class subnet
Aug 17th, 2009
i am trying to configure dhcp pool with classless network address:
network 172.20.1.0 255.255.0.0
default-router 172.20.1.254
but when i do sh run,the router config shows the following:
network network 172.20.0.0 255.255.0.0
is there a command i can use to stop the router from using the default classfull address.
thank you for your help.
Overall Rating: 5 (1 ratings)
Lucien Avramov Mon, 08/17/2009 - 18:49
Well you need to make up your mind:
either you use network 172.20.1.0 255.255.255.0 and that will do what you want or you keep network 172.20.0.0 255.255.0.0
I think you have a typo in your network statement you needed 255.255.255.0
mhasabal Tue, 08/18/2009 - 04:50
lavramov,
thank you for the reply. the reason i need to configure the inside interface and the dhcp pool that way is because i have NEC phone system that i am not familiar with and don't want to change IP address cause it will create a chain of problems.
