08-18-2009 12:53 AM - edited 03-06-2019 07:17 AM
does anybody know which MIB/OIDs I can use to query interface counters especially for multicast and broadcast traffic in bits/bytes (not packet count)?
On the cli I only found the command "show vlan id <VLAN> counter", in the MIBs I found the following OIDs but they only query packet counter and not the amount of transfered traffic in bytes:
* in *ifXTable* (1.3.6.1.2.1.31.1.1):
** 1.3.6.1.2.1.31.1.1.1.2 (*ifInMulticastPkts*: _The number of packets, delivered by this sub-layer to a higher (sub-)layer, which were addressed to a multicast address at this sub-layer._)
** 1.3.6.1.2.1.31.1.1.1.3 (*ifInBroadcastPkts*: _The number of packets, delivered by this sub-layer to a higher (sub-)layer, which were addressed to a broadcast address at this sub-layer._)
** 1.3.6.1.2.1.31.1.1.1.4 (*ifOutMulticastPkts*: _The total number of packets that higher-level protocols requested be transmitted, and which were addressed to a multicast address at this sub-layer, including those that were discarded or not sent._)
** 1.3.6.1.2.1.31.1.1.1.5 (*ifOutBroadcastPkts*: _The total number of packets that higher-level protocols requested be transmitted, and which were addressed to a broadcast address at this sub-layer, including those that were discarded or not sent._)
** 1.3.6.1.2.1.31.1.1.1.6 (*ifHCInOctets*: _The total number of octets received on the interface, including framing characters. This object is a 64-bit version of ifInOctets._)
** 1.3.6.1.2.1.31.1.1.1.7 (*ifHCInUcastPkts*: _The number of packets, delivered by this sub-layer to a higher (sub-)layer, which were not addressed to a multicast or broadcast address at this sub-layer. This object is a 64-bit version of ifInUcastPkts._)
** 1.3.6.1.2.1.31.1.1.1.8 (*ifHCInMulticastPkts*: _The number of packets, delivered by this sub-layer to a higher (sub-)layer, which were addressed to a multicast address at this sub-layer. This object is a 64-bit version of ifInMulticastPkts._)
** 1.3.6.1.2.1.31.1.1.1.9 (*ifHCInBroadcastPkts*: _The number of packets, delivered by this sub-layer to a higher (sub-)layer, which were addressed to a broadcast address at this sub-layer. This object is a 64-bit version of ifInBroadcastPkts._)
** 1.3.6.1.2.1.31.1.1.1.10 (*ifHCOutOctets*: _The total number of octets transmitted out of the interface, including framing characters. This object is a 64-bit version of ifOutOctets._)
** 1.3.6.1.2.1.31.1.1.1.11 (*ifHCOutUcastPkts*: _The total number of packets that higher-level protocols requested be transmitted, and which were not addressed to a multicast or broadcast address at this sub-layer, including those that were discarded or not sent. This object is a 64-bit version of ifOutUcastPkts._)
** 1.3.6.1.2.1.31.1.1.1.12 (*ifHCOutMulticastPkts*: _The total number of packets that higher-level protocols requested be transmitted, and which were addressed to a multicast address at this sub-layer, including those that were discarded or not sent. This object is a 64-bit version of ifOutMulticastPkts._)
** 1.3.6.1.2.1.31.1.1.1.13 (*ifHCOutBroadcastPkts*: _The total number of packets that higher-level protocols requested be transmitted, and which were addressed to a broadcast address at this sub-layer, including those that were discarded or not sent. This object is a 64-bit version of ifOutBroadcastPkts._)
Best Regards,
Thorsten Steffen
Solved! Go to Solution.
08-18-2009 10:52 PM
You can only get the SUM over SNMP for input and output as the example here:
Show vlan counters does not give the information about octects/packets output on a vlan. Also most of the values are 0. Here is the output:
6506-E-1#sh vlan id 51 counters
* Multicast counters include broadcast packets
Vlan Id : 51
L2 Unicast Packets : 16
L2 Unicast Octets : 1834
L3 Input Unicast Packets : 0
L3 Input Unicast Octets : 0
L3 Output Unicast Packets : 0
L3 Output Unicast Octets : 0
L3 Output Multicast Packets : 0
L3 Output Multicast Octets : 0
L3 Input Multicast Packets : 0
L3 Input Multicast Octets : 0
L2 Multicast Packets : 5
L2 Multicast Octets : 405
SNMP however is giving the correct values:
Now SNMP input octects is -
[sj-cse-150]/home/jtamvada> snmpwalk -c public 172.21.56.67
.1.3.6.1.2.1.2.2.1.10.55
IF-MIB::ifInOctets.55 = Counter32: 2239
Here, SNMP vlaue (2239) is sum of L2 Unicast Octets & L2 Multicast
Octets (1834 + 405).
For the output, you can use 1.3.6.1.2.1.2.2.1.16
There is no mib to get the values one by one. That would be an enhancement request.
08-18-2009 07:08 AM
Do you have a show command output showing the counter you want to get?
I was thinking about :
ifInNUcastPkts (.1.3.6.1.2.1.2.2.1.12): These are counts of inbound broadcast and multicast packets.
ifOutUcastPkts (.1.3.6.1.2.1.2.2.1.17):These are counts of outbound broadcast and multicast packets.
08-18-2009 10:14 PM
switch#sh vlan id 123 counters
Vlan Id : 123
L2 Unicast Packets : 13438026979
L2 Unicast Octets : 10893071200183
L3 Input Unicast Packets : 57472951222
L3 Input Unicast Octets : 46852941084144
L3 Output Unicast Packets : 47675105318
L3 Output Unicast Octets : 12501279688609
L2 Multicast Packets : 408660936
L2 Multicast Octets : 28038366077
What I want to get is e.g. the "L2 Multicast Octets" and "L2 Unicast Octets" counter.
Maybe there exist other unicast and multi/broadcast octet interface counters I can get via snmp?
08-18-2009 10:52 PM
Vlan Id : 51
