Bulk Provisioning Tools
Aug 18th, 2009
Hi All,
Are there any bulk provisioning tools other than the standard available with CUCM?
Is it possible to develop some, perhaps using SOAP or some other tool available?
Thanks a lot guys!!!
TF
Jonathan Schulenberg Tue, 08/18/2009 - 06:02
  • Cisco Designated VIP,
    2017 IP Telephony
In addition to BAT and TAPS, which I presume you mean to be the "standard" methods, there is also Cisco Unified Provisioning Manager. I believe it uses the AXL interface to perform the configuration.
Cisco Unified Provisioning Manager 1.3
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6491/ps6705/ps7125/data_sheet_c78-484121.html
Jaime Valencia Tue, 08/18/2009 - 07:57
  • Cisco Employee,
  • Hall of Fame,
    2011
I know Sascha Monteiro (a NetPro) wrote an App that does a lot of the things BAT was unable to do, hopefully he'll look at this.
Or you can search NetPro using his id, i think he posted the info where he can be reached and some info on the app he wrote
java
if this helps, please rate
