ACE: which features are enabled by -> ACE-SEC-LIC-K9
Answered Question
Aug 18th, 2009
  • Bronze, 100 points or more
Our latest ACE Pair is missing the  ACE-SEC-LIC-K9 license.
Inquiry at our Distributor and Cisco resulted in the fact that this license is EOL/EOS.
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/end_of_life_notice_c51-480367.html
Since i have that license installed in 4 other Datacenter Pairs running A2(1.3)i am not sure which feature will be missing now.
Or is that license a relict which actually does not activate any feature?
Anyone a clue or a doc which explains the features behind this license?
Thanks for reading
Roble
Correct Answer by Syed Iftekhar Ahmed about 7 years 11 months ago
If I recall correctly it was a promotional license.
All the ACE-SEC-LIC-K9 features are now part of the base image on ACE.
You can verify the features by running "show license status"
If it shows 1000/ssl transactions/sec, 5 contexts and 4Gbps throughput then it provides same features as base image.
Syed Iftekhar Ahmed
Overall Rating: 0 (3 ratings)
Roble Mumin Tue, 08/18/2009 - 06:13
Hi Sachinga,
have you actually read what i wrote?
I posted the exact same link. And yes i'm running A2(1.3) which i posted as well.
Maybe this is a subtle approach to make me read the doc and end up with the conclusion it is not what i was looking for, again. :)
Roble
Correct Answer
Syed Iftekhar Ahmed Tue, 08/18/2009 - 23:50
  • Blue, 1500 points or more
Syed Iftekhar Ahmed
Roble Mumin Thu, 08/20/2009 - 12:47
Thanks for the helpful answer Syed!
As we have 20 contexts, 5k ssl/sec and 8Gbps i shouldn't really miss it. :)
Roble
