publish web site
jaimewalker
hi,
I am trying to publish a web site on 80.2.100.85/80 and access it from 78.109.177.183. when I try to access the server on port 80, I get the following log message: Deny tcp src WAN:78.109.177.183/64679 dst PRG_LAN:80.2.100.85/80 by access-group "PRG_WAN_access_in" but the config looks right to me. can anybody help?
config below:
global (WAN) 2 80.2.100.75-80.2.100.87 netmask 255.255.255.0
global (WAN) 1 interface
static (PRG_LAN,WAN) tcp 80.2.100.85 www 192.168.123.34 www netmask 255.255.255.255
access-list PRG_WAN_access_in extended permit tcp any host 82.2.100.74 eq ssh
access-list PRG_WAN_access_in extended permit tcp any host 82.2.100.84 eq www
access-list PRG_WAN_access_in extended permit tcp any host 82.2.100.85 eq www
access-group PRG_WAN_access_in in interface WAN
10 Replies 10
andrew.prince
Level 10
Level 10
issue on the cli "clear xlate" and try again, also put a line at the bottom of the acl:-
access-list PRG_WAN_access_in extended deny ip any any log
then check your logs.
HTH>
hi,
unfortunatly clear xlate didn't help
and the log information is not showing me anything else.
post the output from:-
show xlate
show access-list
attachment added with output
OK - my ovbservations:-
1) you did get a hit for the http acl for the web server - check your server is actaully listening on tcp port 80
2) You are getting alog of denies - are you trying to access the website via DNS or direct IP
3) Is by DNS check the IP address the url is resolving to is the same as the acl & static nat
4) Try changing the PAT to a NAT:-
remove
replace
static (PRG_LAN,WAN) 80.2.100.85 192.168.123.34 netmask 255.255.255.255
And re-test.
hi,
I can successfully telnet 192.168.123.34 80 so I believe the server is listening on port 80
My test is to telnet 80.2.100.85 80 rather than use DNS
I have done a NAT translation as advised but still no look
Where are you testing from, the inside or the outside?
Check your NAT/ACL again
I have tested it from inside and 2 x outside locations but still no luck. I will check the NAT/ACL again.
Thanks for your help
wood for the trees....
the problem was a typo in the ACL. I was putting 82 instead of 80 in the first octet.
sorry
np - glad to help.
