Group authentication without Easy VPN?
Aug 18th, 2009
I have a 1841 router running IOS 12.4 that is to be deployed as an IPsec spoke router. The remote side on which the IPsec tunnel terminates uses XAuth groups to match IPsec clients and to apply appropriate configuration.
I would like to ask if there is a way to specify the XAuth group name on the spoke router without configuring it as Easy VPN Remote. I want to use the classical IPsec configuration but I just wonder if it is possible to specify the group in this case.
Thank you very much for any advice!
Best regards,
Peter
