NAT incoming SSL traffic to inside interface address
Aug 18th, 2009
Hi All,
I'm trying to NAT the source address of incoming ssl traffic to the physical inside interface. So on the inside network all ssl traffic should be sourced from the inside interface.
Does anyone know if this is possible? I was trying something like this...
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 172.16.1.1 255.255.255.0
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.0.1.2 255.255.255.0
global (inside) 1 interface
nat (outside) 1 10.0.2.0 255.255.255.0
ip local pool SSL-IP-POOL 10.0.2.1-10.0.2.254 mask 255.255.255.0
tunnel-group TEST general-attributes
address-pool SSL-IP-POOL
Hielke
HHagendoorn Tue, 08/18/2009 - 22:32
Hi Andrew,
Thx for you reply. Excusse me for not begin clear about this.
I'm trying to NAT the decrypted client traffic (so the traffic sourced from the pool addresses), not the ssl traffic (source from the real client address).
It seems to me your answer reverse to the second situation, where I meant to ask for the first one.
Any suggestions?
Hielke
