Unity Express - CUE, Application Mode CallManager not Express
Aug 18th, 2009
Anyone know how to change the "application mode" of CUE to CME and not CCM? Is this based on the license? I have a CME and not CCM and somehow the config got set for CCM, even though I have done a clean install.
Overall Rating: 0 (2 ratings)
Markus Schneider Tue, 08/18/2009 - 08:11
Try a 'software install clean' of the CCM license file. That's what defines what mode it's in.
mknepper Tue, 08/18/2009 - 08:14
Problem is I don't have an license file. The NME module came preloaded with software and license, but I ran into problems and had to reinstall which erased the contents of the NME disk.
Rob Huffman Tue, 08/18/2009 - 08:49
Hi Mark,
On the upper right-hand side of this page search all Cisco.com for;
cue license
You will see the various files "specific" to either ccm or cme. In the examples below you would use number 2;
Download Software for : cue-vm-license_12mbx_ccm_7.0.2.pkg
Download Software for : cue-vm-license_12mbx_cme_7.0.2.pkg
Hope this helps!
Rob
MehmetKaya Tue, 06/22/2010 - 06:53
ı add this (Download Software for : cue-vm-license_12mbx_ccm_7.0.2.pkg) with software install clean command and my problem was solved.
cue# show software licenses
Installed license files:
- voicemail_lic.sig : 12 MAILBOX LICENSE
- ivr_lic.sig : NULL IVR LICENSE
Core:
- Application mode: CCM
- Total usable system ports: 6
Voicemail/Auto Attendant:
- Max system mailbox capacity time: 840
- Default # of general delivery mailboxes: 5
- Default # of personal mailboxes: 12
- Max # of configurable mailboxes: 17
Interactive Voice Response:
- Max # of IVR ports: Not Available
Languages:
- Max installed languages: 2
- Max enabled languages: 2
jpoplawski Thu, 02/23/2012 - 11:25
Thanks for the help guys, saved me a call to TAC.
I ran through initialization and couldn't specify MWI or anything.  Got on-site, looked into it, CCM mode it is!
Swapped, reloaded, onto more installation tasks.
Cheers!!!
JB
