renumber the image order on a flash directory
Answered Question
Aug 18th, 2009
any one knows how to renumber the files on the flash dir.
Correct Answer by Giuseppe Larosa about 7 years 5 months ago
Hello Ocporbust,
use boot system flash command to load the desired image regardless of image order on flash
see
sh run | inc boot system
boot system flash disk2:c7200p-advsecurityk9-mz.124-20.T.bin
boot system flash disk2:c7200p-advsecurityk9-mz.124-4.XD3.bin
this router loads the first image in this way.
you can check with:
sh bootvar
BOOT variable = disk2:c7200p-advsecurityk9-mz.124-20.T.bin,1;disk2:c7200p-advsecurityk9-mz.124-4.XD3.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
WARM_REBOOT variable = FALSE
when you need to change the order:
copy current boot system commands on an editor
issue no boot system ... for each line
input them in the desired order preferred image first
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 08/18/2009 - 07:49
Hello Ocporbust,
see
you can check with:
sh bootvar
Hope to help
Giuseppe
