MDS9134 failing inventory and config archive
wilson_1234_2
Level 3
Level 3
LMS 2.6
RME 4.0.6
We have an MDS9134 that is failing config archive with error message
CM0056 Config fetch failed for DR-9134-01 Cause: CM0204
Could not create DeviceContext for 226 Cause: CM0206
There are no device or software updates using software center.
If is a device package problem, is there a work around for this version of RME?
Joe Clarke
What is the sysObjectID of this switch? The error looks like lack of device support.
This is what is showing up when adding the device in Common Services:
OID:1.3.6.1.4.1.9.12.3.1.3.616
RME support for this device is not available until 4.1.1 (LMS 3.0.1). Only Campus supports this device in LMS 2.6.
