CME Checksum Errors on Extract to Router...
Aug 18th, 2009
Running 124-24T, CME Full 7.1.0.1.tar every time I run archive tar /xtract tfpt://x.x.x.x/cme-full-7.1.0.1 flash: it gets few the first few files then flakes out...
7 2918613 apps42.8-4-1-23.sbn
8 6964 CME-7-1-basic-readme-v.1.1.txt
9 463556 cnu11.8-4-1-23.sbn
10 459836 cnu41.8-4-1-23.sbn
11 485066 cnu42.8-4-1-23.sbn [invalid checksum]
12 894 CP7921G-1.2.1.LOADS [invalid checksum]
13 2666103 cvm11sccp.8-4-1-23.sbn [invalid checksum]
14 2660448 cvm41sccp.8-4-1-23.sbn [invalid checksum]
15 2659498 cvm42sccp.8-4-1-23.sbn [invalid checksum]
16 335003 dsp11.8-4-1-23.sbn [invalid checksum]
17 539441 dsp41.8-4-1-23.sbn [invalid checksum]
18 335003 dsp42.8-4-1-23.sbn [invalid checksum]
19 3987 gui/admin_user.html [invalid checksum]
20 677822 gui/admin_user.js [invalid checksum]
21 1029 gui/CiscoLogo.gif [invalid checksum]
22 617 gui/CME_GUI_README.TXT [invalid checksum]
23 953 gui/Delete.gif [invalid checksum]
24 16344 gui/dom.js [invalid checksum]
25 864 gui/downarrow.gif [invalid checksum]
26 6146 gui/ephone_admin.html [invalid checksum]
27 4558 gui/logohome.gif [invalid checksum]
28 3866 gui/normal_user.html [invalid checksum]
29 78428 gui/normal_user.js [invalid checksum]
30 1347 gui/Plus.gif [invalid checksum]
31 843 gui/sxiconad.gif [invalid checksum]
32 174 gui/Tab.gif [invalid checksum]
33 2431 gui/telephony_service.html [invalid checksum]
34 870 gui/uparrow.gif [invalid checksum]
35 9968 gui/xml-test.html [invalid checksum]
36 3412 gui/xml.template [invalid checksum]
37 1833102 GUI-1.2.1.SBN [invalid checksum]
38 485341 jar11sccp.8-4-1-23.sbn [invalid checksum]
39 500440 jar41sccp.8-4-1-23.sbn [invalid checksum]
40 628112 jar42sccp.8-4-1-23.sbn [invalid checksum]
41 496521 music-on-hold.au [invalid checksum]
42 658 SCCP11.8-4-2S.loads [invalid checksum]
43 638 SCCP41.8-4-2S.loads [invalid checksum]
44 658 SCCP42.8-4-2S.loads [invalid checksum]
45 2083047 SYS-1.2.1.SBN [invalid checksum]
46 662 term06.default.loads [invalid checksum]
47 662 term11.default.loads [invalid checksum]
48 642 term41.default.loads [invalid checksum]
49 662 term42.default.loads [invalid checksum]
50 642 term61.default.loads [invalid checksum]
51 662 term62.default.loads [invalid checksum]
52 895905 TNUX-1.2.1.SBN [invalid checksum]
53 2196478 TNUXR-1.2.1.SBN [invalid checksum]
54 1350650 WLAN-1.2.1.SBN [invalid checksum]
55 5134 7970-71-75-Background-readme-v1.txt
56 2593969 APPS-1.2.1.SBN
57 2925555 apps11.8-4-1-23.sbn
58 2925555 apps31.8-4-1-23.sbn
59 7892498 apps37sccp.1-2-1-0.bin
60 2915997 apps41.8-4-1-23.sbn
61 2918613 apps42.8-4-1-23.sbn [invalid checksum]
62 1868800 apps45.8-4-1-23.sbn [invalid checksum]
[157186096 bytes used, 1860233164 available, 2017419260 total]
1970136K bytes of ATA CompactFlash (Read/Write)
I tried 7.1.0.0 and it's the same thing. What the heck?
Jeffrey Knuckle Tue, 08/18/2009 - 10:14
Try to download a new copy of the file then use a program like MD5SUM to compare the checksum of the downloaded file with value listed under File Details on the download page, the value should match exactly.
