Limit Telnet => ASA to one AD group
Aug 18th, 2009
I want to restrict CLI access to our ASA 5510 to one Active Directory group. Currently the ASA authenticates against our LDAP/AD server, and anyone in the organization can log into the ASA using HyperTerminal (enable password is another matter, however).
How can I narrow such access to only our IT group, which has its own AD container?
Thanks in advance,
-- Bill
jan.nielsen Tue, 08/18/2009 - 12:24
  • Gold, 750 points or more
You need to specify that OU where these ppl are located in the base dn string in the aaa definition of your LDAP server, then your asa will only look in that part of your AD.
william-white Tue, 08/18/2009 - 13:08
OK, this is valuable. Would this also limit VPN access to the people in that OU? I want to limit only telnet into the CLI.
Jatin Katyal Tue, 08/18/2009 - 14:56
  • Cisco Employee,
No, this won't restrict access for VPN users in that OU because we are only configuring it for TELNET access.
Here is a config example:
aaa-server protocol ldap
aaa authentication telnet console LOCAL
aaa authorization exec authentication-server
ldap attribute-map
map-name memberOf IETF-Radius-service-type
map-value memberOf service-type 6
aaa-server host
ldap-base-dn
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-dn
ldap-login-password
server-type microsoft
ldap-attribute-map
For more info, you may refer:
Limiting User CLI and ASDM Access with Management Authorization
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/mgacc
ess.html#wp1070306
Hope this helps.
william-white Wed, 08/19/2009 - 08:19
Thanks for the help on this. What I've done is to remove AD/Radius authentication entirely from ASA login (ASDM,Telnet,SSH), going strictly with LOCAL accounts. This ensures run-of-the-mill users can't sign into the ASA over the network, and contiues access in case my AD server goes down and I need to get into the ASA.
