Cisco 2500 Router and a Linux Router
Tavis10284
All,
I am working on getting a Cisco 2500 router working with a Linux router (IPcop) that is my gateway out to the Internet. My network topology is attached in .png format.
Essentially, I have the IPCop Linux router connected to a D-Link layer 2 gigabit switch. The Cisco 2500 is connected via E0 to a port on the D-Link switch with IP address 192.168.1.8. E1 on the 2500 is connected to a PC using a crossover cable with IP address of 192.168.3.1. The PC has 192.168.3.2.
My results:
The PC at 192.168.3.2 can ping 192.168.3.1 and 192.168.1.8
My problems:
The PC at 192.168.3.2 cannot ping 192.168.1.1 or any other PC on the 192.168.1.0/24 network.
Now if I SSH into my Linux router and do:
ip route add 192.168.3.0/24 dev eth0
I can then ping the router from the PC at 192.168.3.2, but I cannot ping any other IP on 192.168.1.0/24 other than 192.168.1.1 and 192.168.1.8, nor to any public WAN IP.
I have not enabled any routing protocols on R1 as I don't think there is a need for it yet. I haven't configure R2 as I am trying to get R1 to work properly before messing with routing protocols and R2.
I've tried:
ip default-gateway 192.168.1.1
and tried these two together:
ip default-network 192.168.1.0
ip route 0.0.0.0 0.0.0.0 e0
I am pretty certain I need to configure the Linux router to essentially tell it that "yes, 192.168.3.0/24 exists. You can reach it by your NIC Eth0 and by IP 192.168.1.1 as the next hop. The IP address you are looking for is 192.168.1.8"
Can anyone help me get this working? I am not looking to run any NAT unless I absolutely have to.
28 Replies 28
John Blakley
Try removing your ip default-gateway lines from the router and remove the ip default-network line as well.
Try changing your 2500 to:
ip route 0.0.0.0 0.0.0.0 192.168.1.1
You're still going to need a route of some sort from your Linux box into the 192.168.3.0/24 network, but you shouldn't need nat for this to work.
HTH,
John
HTH, John *** Please rate all useful posts ***
OK - I added ONLY:
to the 2500 (R1) and now I can ping google.com from my router. Good.
I am still unable to ping any IP addresses from the PC at 192.168.3.2 EXCEPT, 192.168.3.1, 192.168.1.8, and now 192.168.1.1.
My DNS servers are at 192.168.1.2 and 192.168.1.10, so I will need to be able to reach them to get these other subnets working on the net (at least as far as name resolution goes).
On my IPCop router, I have tried these commands:
route add -net 192.168.3.0 netmask 255.255.255.0 eth0
and
route add -net 192.168.3.0 netmask 255.255.255.0 gw 192.168.1.8 eth0
route -e returns the default routing table:
root@ipcop-tc:~ # route -e
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
(My public IP here) * 255.255.255.128 U 0 0 0 eth2
192.168.1.0 * 255.255.255.0 U 0 0 0 eth0
192.168.0.0 * 255.255.255.0 U 0 0 0 eth1
default user-0c99441.ca 0.0.0.0 UG 0 0 0 eth2
If I run:
This is the result:
192.168.3.0 192.168.1.8 255.255.255.0 UG 0 0 0 eth0
If I run:
route add -net 192.168.3.0 netmask 255.255.255.0 gw 192.168.1.1 eth0
This is the resulting table:
192.168.3.0 ipcop-tc.tc 255.255.255.0 UG 0 0 0 eth0
If I run:
root@ipcop-tc:~ # route add -net 192.168.3.0 netmask 255.255.255.0 eth0
(My Public IP here) * 255.255.255.128 U 0 0 0 eth2
192.168.3.0 * 255.255.255.0 U 0 0 0 eth0
But unfortunately, I'm still unable to ping any IP address from the PC at 192.168.3.2 EXCEPT, 192.168.3.1, 192.168.1.8, and now 192.168.1.1. =(
If I get it correctly, you have two gateways on 192.168.1.0: your 2500 and the linux router. Hosts on the network will need a route statement for 192.168.3.0 pointing to the 2500, in addition to a default route pointing to the linux host.
If they don't, they'll send traffic for 192.168.3.x to the wrong next hop. The Linux box might send out a ICMP Redirect, and your PCs might listen to that Redirect, but don't count on it.
If I understand my terminology correctly, the 2500 isn't a gateway out to the Internet except for the 192.168.3.0/24 subnet. It is not directly connected to the cable modem, just a switch that connects to the 192.168.1.1 router.
Still, hosts on the 192.168.1.0 network need to know how to reach the 192.168.3.0 network. The gateway for that particular network will be your R1 (note that it is not a "default gateway", but only for destinations in 192.168.3.0) That is why you will have to add a route on those hosts.
So I tried adding a second gateway on 192.168.1.10, one of my DNS servers, and then tried to ping from 192.168.3.2 to 192.168.1.10 and it still refuses to ping. Is that what you meant?
Another side note:
I can now surf the web using the 192.168.3.2 PC using the DNS servers on the 192.168.1.0/24 subnet. They are resolving, and NSLOOKUP works fine on the PC, but yet I still can't ping them. I'm not sure what's happening.
Currently on my router I have this for a routing table:
Destination Gateway Genmask Flags Metric Ref Use Iface
(my public subnet) * 255.255.255.128 U 0 0 0 eth2
Is it something else I need to add to the IPCop Linux router?
I'm sorry to be so n00b. I've only connected up Cisco to Cisco routers before.
"They are resolving, and NSLOOKUP works fine on the PC, but yet I still can't ping them. I'm not sure what's happening. "
It sounds like ICMP is disabled somewhere (I suspect IPCop).
A couple of tests:
Can you ping from 192.168.1.8 (cisco router) to the inside interface on your IPCop router?
From the IPCop router, can you ping 192.168.1.8 (cisco router)
From 192.168.3.2, can you ping inside interface of IPCop?
From IPCop, can you ping 192.168.3.2.
You don't have an overly complicated setup, so all traffic should be passing fine unless there's a firewall configured on your Linux box like IPTables. If you have IPTables configured, you'll need to add exclusions for the 192.168.3.0/24 subnet.
HTH,
John
"Can you ping from 192.168.1.8 (cisco router) to the inside interface on your IPCop router? "
From the Cisco 2500 router (R1), yes, without modifying the Linux routers' route table.
"From 192.168.3.2, can you ping inside interface of IPCop?"
Not if the Linux routers' routing table is left at defaults.
But yes if I run:
"From IPCop, can you ping 192.168.3.2."
But yes if I run:
The IPCop route does have a builtin firewall.
I've never worked with iptables unfortunately. =(
IPtables output attached in .txt file
Deleted iptables attachment and reattached due to personal info.
I am beginning to think it is more of a problem on the Cisco router (R1) side than my Linux router. I can ping all the way into the 192.168.3.2 network just fine after I add a route statement on the Linux router. However, I cannot ping out to the 192.168.1.0/24 network other than 192.l68.1.1 and 192.168.1.8
Here is my running config:
TC-R1#sh run
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname TC-R1
ip subnet-zero
ip name-server 192.168.1.2
ip name-server 192.168.1.10
interface Ethernet0
ip address 192.168.1.8 255.255.255.0
no ip directed-broadcast
interface Ethernet1
ip address 192.168.3.1 255.255.255.0
interface Serial0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
ip classless
line con 0
transport input none
line aux 0
line vty 0 4
login
end
TC-R1#
Flash:
TC-R1#sh flash
System flash directory:
File Length Name/status
1 6788464 C2500-d-l.120-4
[6788528 bytes used, 1600080 available, 8388608 total]
8192K bytes of processor board System flash (Read ONLY)
I connected up and configured a Cisco 1710 router with the same IPs and similar config and I have the same issue with this router too. =(
Tavis,
just going through the thread...
what machine is 192.168.1.1? I assume it's the Linux router?
The route for 192.168.3.0/24 should be pointing at the 192.168.1.8 address that you have on your drawing.
I would also be interested in the results of an extend ping to the ipcop router. the extended ping should identify 192.168.3.1 as the source interface.
thanks
Tony
Tavis,
I think it's your Linux box causing the issue and not the router. You'll need to have a route for the 192.168.3.0 subnet on the Linux box, or else it doesn't know where to send the packet back. The workstation needs to have the 192.168.3.x address of the router's inside interface listed as it's gateway. Other than that, your router is configured correctly for what you're doing with it.
BTW, you'll need a default route on the Cisco router like:
The routes on the Linux box have to stay for the 192.168.3.0 subnet.
HTH,
John
