ACS 5 Custom RADIUS attribute?
Aug 18th, 2009
We are testing ACS 5 with Cisco and Juniper switches. Everything is working well, except we need to use a certain Juniper RADIUS attribute for downloadable filters (think downloadable ACL). The attribute is not listed in the ACS -> Config -> Dictionaries -> Protocols -> RADIUS -> Juniper section, and I cannot see a way of adding/editing the dictionary.
Any ideas?
Gustavo Novais Wed, 08/19/2009 - 04:22
I've also tested ACS5 a while ago with Cisco, HP, and other manufacturers...
Unfortuinaltely that's one of the points where ACS 5 is not yet mature...
Attribute addition is not yet supported, but will definitely be in roadmap.
There was an ask the expert event a few months ago about ACS5. You might want to take a look at that.
Best of luck
Gustavo Novais
Lucien Avramov Wed, 08/19/2009 - 07:13
I believe ACS 5.1 will have this feature, ACS 5.0 is limited in this regards. If this can not wait, you may use ACS 4.2
Robert.N.Barrett_2 Wed, 08/19/2009 - 12:48
Thank you both for the replies. I'll check out the Ask the Expert, and I am now loading up ACS 4.2 eval to check it out. Looks like CSUtil.exe and I are going to get very chummy.
Trending Topics - Security & Network
