Upgrading IOS on 3550 to enable BGP v4
I am currently running a 3550 with System image file:
"flash:c3550-i5q3l2-mz.121-9.EA1c/c3550-i5q3l2-mz.121-9.EA1c.bin"
cisco WS-C3550-12G (PowerPC) processor (revision B0) with 65526K/8192K
i would like to upgrade to the following IOS to enable BGP. Can anyone see any issues with this?
Release 12.2.50-SE3
Filename c3550-ipservicesk9-mz.122-50.SE3.bin
Release Date 28/Jul/2009
Minimum Memory DRAM:64 MB Flash:16 MB
Size 9928.45 KB (10166732 bytes)
Router Checksum 0x2e75
MD5 91d758c2d2e50cb4cecff0ca31383ee
Overall Rating: 3 (1 ratings)
jbrenesj Tue, 08/18/2009 - 16:49
  • Silver, 250 points or more
All 3550 have the same hardware characteristics so no problem going from such an old IOS like 12.1(9) to the latest.
DRAM and CPU will be OK, just not sure if both versions fit in flash:, if not you'll need to delete the old one.
I guess you have the license to run ipservices so I don't see a a problem.
In case you want to enhance the number or supported routes you can use the "sdm prefer routing" template
Edison Ortiz Tue, 08/18/2009 - 16:52
  • Hall of Fame,
    Founding Member
I don't see any issue - just as FYI - your current IOS supports BGP.
HTH,
__
Edison.
