Missing Icons at Cisco Unity Express
Aug 18th, 2009
I am using CME ver7.0 & CUE ver7.0.1 at my office.
When I go to Cisco Unity Express using web link, I cannot access "Extensions" & "Phones" feature. All the icons are missing & page become hangs.
Anybody can tell me what I need to do for solve this problem?
Overall Rating: 1 (1 ratings)
irisrios Mon, 08/24/2009 - 05:39
Post the outputs from the router:
show run
show version
show flash
MaungSanYu Thu, 08/27/2009 - 22:21
Hi irisrios ,
Sorry for late post & reply.
I tried to post my "show run, show version & show flash" but that is over limited characters.
If you have email address, I can send it to you.
Juan Carlos Ari... Thu, 08/27/2009 - 10:43
Hi Maung,
You have to copy all GUI files to the flash and add this command if the files are located at flash:/gui directory:
ip http path flash:/gui
You can try copying again all of them.
Hope this helps,
JC Arias
MaungSanYu Thu, 08/27/2009 - 22:47
Hi jcperez,
I am using CME ver7.0 & CUE ver7.0.1 . I think most of the GUI files are inside the flash. I am not putting files inside " flash:/gui directory".
anyway, thank for the reply.
ahmed-hassan1110 Wed, 10/21/2009 - 03:35
Hi All,
i have CME version 7.1 with IOS 12.4(24T1)and i experienced the same problem with the GUI interface. i found that the problem came from copying the GUI files using a flash reader, when i uploaded the files using the archive command the GUI worked fine but after a restart.
