NetManager License
Aug 18th, 2009
I just installed Cisco Netmanager two weeks back and I have a problem which I suspect might be related to the hardware. the problem I have is that licensing is done according to the mac addresses.
Is there a way to transfer the license to the new machine? the want to install the netmanager in a new machine.
dsweeny Mon, 08/24/2009 - 13:14
Can you be more specific about the problem you are facing. Netmanager licensing uses node-locking technology. The license file can only be used with the MAC address that you supply.
