08-18-2009 10:09 PM - edited 07-03-2021 05:57 PM
The LWAPP-upgrade on a AP 1131AG faield with the following error message on the upgrade-tool:
"AP does not have supported radio"
On the AP is still the autonomus image.
Does anyone have an idea?
08-18-2009 10:25 PM
Are you trying to upgrade from Autonomous to LWAP using the upgrade tool?
Upgrading Autonomous Cisco Aironet Access Points to Lightweight Mode
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
Hope this helps.
08-18-2009 11:01 PM
this was a message we were getting all the time when trying to convert the 1230 that have radios not supported in LWAPP (the old .a radio).
Per the release notes, the 1131AG is supported for conversion, I'm not sure why you get this message.
Nevertheless you still should be able to convert the AP.
Make sure to follow the procedure send by leolaohoo
01-11-2012 07:17 PM
Me too getting the same error. Please check if your AP is damaged one?
Mangesh Bhende
01-11-2012 07:29 PM
while the AP is running iOS can you pull a show controllers dot11radio 0 and 1?
