Buzzing noise from the IP Phone
Answered Question
Aug 18th, 2009
We recently upgraded to CUCM 6.1.3(b) from 4.X. Now, we receive a buzzing kind of sound when the speakers are turned on-on a call. We tried upgrading the firmware of 7941G from SCCP41.8-4-2S to SCCP41.8-4-4S. But, we still have the same issue. Can you pl suggest solution.
Regds
Karthik
Correct Answer by Rob Huffman about 7 years 8 months ago
Hi Karthik,
You may be hitting this bug;
CSCsz68389 Bug Details
Noise Reduction causes saturated speech on Handsfree Send
Symptom:
When talking on the speakerphone, far end listeners may hear voice clipping. The talker's voice may sound like a buzz.
Conditions:
This issue is most noticeable when the talker is using the speakerphone.
Workaround:
The talker can sit farther away from the phone, talk in a lower voice or use the handset or headset.
Further Problem Description:
Status
Fixed
Severity
3 - moderate
Last Modified
In Last 2 weeks
Product
Cisco Unified IP Phones 7900 Series
Technology
1st Found-In
8.5(2)
Fixed-In
8.5(2)CA1.2
8.5(3)MN1.8
8.4(4)ES7
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 08/19/2009 - 04:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Karthik,
Symptom:
Conditions:
Workaround:
Status
Fixed
Severity
3 - moderate
Last Modified
In Last 2 weeks
Product
Technology
1st Found-In
8.5(2)
Fixed-In
8.5(2)CA1.2
8.5(3)MN1.8
8.4(4)ES7
Hope this helps!
Rob
karthiksr Wed, 08/19/2009 - 04:46
Thanks Rob.
I have CCO credentials to download. Can u pl provide the link for
8.5(2)CA1.2
8.5(3)MN1.8
8.4(4)ES7
Thanks & Regds
Karthik
karthiksr Wed, 08/19/2009 - 09:11
Hi Rob,
We could not find the version(Fixed in) in cisco. So we are raising a case with them to sought this out.
Thank u.
Regds
Karthik
