08-18-2009 10:36 PM - edited 03-18-2019 10:31 AM
Dear All,
I m running CME version 7.0 and CUE version 2.1.
My question is that does CME v7 is compatible with CUE v 2.1.
As i m not able to access my CUE through GUI.
Malik.
Solved! Go to Solution.
08-20-2009 04:48 AM
Hi Malik,
Sorry about that my friend! It should be;
Table 1: Cisco Unity Express: Unified CM Express and Unified SRST Versions
Not Table #2
Cheers!
Rob
08-19-2009 12:20 AM
i think you need post your CME configuration.
they are compatible.
08-19-2009 04:30 AM
Hi Malik,
This document does not show support for CUE 2.1 with CME 7.0;
Cisco Unity Express Compatibility Matrix (Check Table #2)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
Hope this helps!
Rob
08-19-2009 10:18 PM
Hi Rob,
Thanks for you reply...but when i see in table #2 its a comparison between CM and CUE not between CME and CUE...so can you plz advise...
Malik.
08-20-2009 04:48 AM
Hi Malik,
Not Table #2
Cheers!
Rob
