ASDM or SSH cannot login
Aug 19th, 2009
ASA Version 8.0(3)
ASDM 6.11
Cannot login to an ASA 5520 using asdm or SSH just hangs on the login screen. This has been working fine for the last few months. I can still connect to the ASA via telnet from the one permitted ip address. Do I need to enter a 'crypto key generate rsa' command?
There have been no recent changes to the device is this something that can break or needs renewing periodically?
As always thanks for your help.
Collin Clark Wed, 08/19/2009 - 05:24
  • Purple, 4500 points or more
Yes you need to create a key for any secure method of administration, such as ssh or asdm.
PIX(config)#hostname PIXOne
PIXOne(config)#domain-name mydomain.com
PIXOne(config)#ca generate rsa key 1024
PIXOne(config)#ssh time-out 60
PIXOne(config)#ssh 0.0.0.0 0.0.0.0 inside
PIXOne(config)#username somedude password MySeCrEtPaSsWoRd
sjones1966 Thu, 08/20/2009 - 23:11
Thank you - I'm still not certain what the problem was - the ASDM and SSH had been working on this device and just failed one morning with no changes having been made to the config. I backed up the running config and copied it to a spare ASA ssh and ASDM worked fine on that. I rebooted the faulty asa this morning and everything is fine again can use ASDM and SSH to it. Would applying your command:
have saved me the bother of the the reboot?
