08-19-2009 02:11 AM - edited 07-03-2021 05:57 PM
Hi, i've read that phones 7920 are not officially supported by AIR-LAP1252. But, are they supported when you work with autonomus 1252?
Thanks!
Solved! Go to Solution.
08-20-2009 06:06 AM
Hi Mario,
Just to add a doc to the great tips from Michael (+5 points here Michael :)
Cisco Unified Wireless IP Phone 7920 Version 3.0
Access-Point Support
Cisco Aironet access points, including the Cisco Aironet 1300, Aironet 1200, Aironet 1100, Aironet 350, and Aironet 340 series, the Cisco Aironet 1100 Series Lightweight, and the Cisco Aironet 1130
Hope this helps!
Rob
08-19-2009 09:17 AM
No the 7920 is not supported on the AP1250 platform in either Unified (lwapp/capwap) or autonomous mode.
There are some TKIP interop issues there.
Also no new APs were qualified after end of sale of the 7920 back in 2007.
The 7921/7925 are supported on the AP1250 platform.
08-19-2009 10:45 AM
Thank you for your reply. Do you know where can i find a document saying that so i can show it to my customer?.. i trust on you, but a forum reply will not be enough for him :(
08-20-2009 06:06 AM
Hi Mario,
Hope this helps!
Rob
08-20-2009 08:16 AM
Thank you very much! This will help for sure!
08-20-2009 12:30 PM
Not sure if we supported the AP340, that us a pretty old platform.
Also a typo there, where the lightweight ap should say 1000 series not 1100. Also 1240 should be added to the supported list.
09-30-2009 06:40 AM
Does anyone know if the 7920 will actually work with a 1252? I'm about to deploy a 4400 with 1140's and 1252's running 6.0.182.0 code. This is an upgrade where the site is currently using autnomous 1231's (the 1231's are being replaced with the new AP's). The site currently has a few 7920 handsets that they would like to use. It's not crucial that they work, but I don't want to spend a few hours banging my head against the wall trying to make these things work.
09-30-2009 07:51 AM
See my comments above.
The 7920 is not supported on the 1140 & 1250 ap platforms.
Recommend the customer to migrate to the 7921 or 7925, where the 1140 & 1250 series aps are supported.
10-01-2009 07:39 AM
Thanks - I figured "not supported" meant "some configurations might work, but might not, and Cisco will not provide support either way". Since the client is not using TKIP, I figured the phones might work, but that we would get no support from Cisco. The client is prepared to purchase new handsets, but is OK with using their current ones in an unsupported configuration for a little while longer.
