Get a DID from a FXS port on a 2811 to a T.38 Sip trunk
I have a analogue line from a provider here in China problem is they cannot give when I answer the line a DID or Dnis.
topo
analogue pstn----fxs card in GW---Sip trunk--- Cisco Fax Server
Can I connect this analogue line to a FXS on that GW then a dialpeer that gives me the extension number DID when y Fax servers answers the call?
Marco
paolo bevilacqua Wed, 08/19/2009 - 03:43
  • Hall of Fame,
    Founding Member
No. DID on analog lines is supported in North America only. In china, you need ISDN BRI or PRI to receive DID.
Note, you use FXO to connect to PSTN, not FXS.
paolo bevilacqua Wed, 08/19/2009 - 05:07
  • Hall of Fame,
    Founding Member
Sure, you can set a fixed destination with "connection plar" and all faxes would go there.
Please remember to rate useful posts with the scrollbox below.
paolo bevilacqua Wed, 08/19/2009 - 06:57
  • Hall of Fame,
    Founding Member
Yes, called-number = DNIS = plar target.
