VG224 as SCCP in SRST mode
Aug 19th, 2009
I`ve now configured the VG224 as SCCP in CCM and with
SCCP CCM X.X.X.X PRIORITY 10
SCCP CCM SRST PRIORITY 20
All is working with the VG being registered with the SRST router in fall back mode . If I do a SHOW EPHONE REGISTER on the SRST I can see the ANG GW and if I do a SHOW SCCP ALL on the VG224 I can see the ports registered also to the SRST Router however if I call one of the ports based upon the DN I`ve configured in CCM I get busy. I`ve configured on the Voice-port in the VG224 CALLER-ID ENABLED - any ideas. Also if I do a SHOW EPHONE REGISTERED in the SRST router I can see the DN`s of my other IPT Phones- 794x, 76x but where on the same output would I see Analogue port DN`s
many thanks
bettear Wed, 08/19/2009 - 08:51
What version of IOS are you using? I had a similar problem and upgraded the router and VG to 12(4)22T and that fixed the issue.
