Cannot Add WAN Connection on 1812 via SDM
Aug 19th, 2009
I am trying to use the Cisco SDM Express Wizard to initially configure a 1812 ISR. During the wizard, at the "Internet (WAN)" page, I am instructed to choose an interface (FE0 and FE1 show up) and click the "Add Connection" button to enter connection parameters (where I assume I would have to enter IP, PPPoE authentication, etc.). However, selecting either FE interface and clicking the "Add Connection" button does nothing and I cannot proceed with the wizard (unless I forego configuring a WAN connection).
I know I can configure it easily through the CLI, but I need to use the wizard this time for demonstration purposes.
Anyone have any ideas?
Paolo Bevilacqua Wed, 08/19/2009 - 05:03
  • Hall of Fame,
    Founding Member
You should give up with the SDM, there are many things that doesn't do well or not at all, by the time it's fixed (if ever), it will be deficient in some other other areas anyway.
