Best practice to rely 2 sites with CCM7
Aug 19th, 2009
What is the best practice to rely two (2) sites with CCM7?
Should I use gatekeeper?
Should be the Voice gateway will be a gatekeeper and a h323 Voice Gateway?
Best regards
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 08/19/2009 - 05:00
  • Hall of Fame,
    Founding Member
You don't need a gatekeeper. Just configure each remote as ICT trunk with the right numbers and that's it.
iantra123 Wed, 08/19/2009 - 05:27
And how about RSVP ? CAC ?
I don't understand when I'll use gatekeeper, and When i just use a H323 Gateway or How CCM will manage the codecs?
I already read the SRND but i don't understand the usage of these devices.
The network diagram is in the attached file.
Don't keep realy the site in the othercountry.
paolo bevilacqua Wed, 08/19/2009 - 05:30
  • Hall of Fame,
    Founding Member
If you have bandwidth as is common these days, you don't need to worry about these things.
If you don't, configure the remote as g.729. Since all the phones can do that, no transcoding is necessary.
