08-19-2009 05:30 AM - edited 03-21-2019 01:26 AM
We have a site with 6 FXO lines. They want extensions 201 and 202 to make outgoing calls on 0/1/0, 0/1/1, or 0/1/2. All other calls should go out 0/1/3, 0/2/0, and 0/2/1.
What is the easiest way to accomplish this?
08-19-2009 05:40 AM
The easiest way to do this is to configure the system in hybrid mode. Extensions 201 and 202 will have a unique button-to-line mapping (key system), while the other extensions can do PBX with the rest of the PSTN lines.
Marcos
08-19-2009 05:54 AM
Are there instructions anywhere showing how to set that up?
Thanks for the help.
08-19-2009 05:59 AM
Yes, the complete First Look v1.4 Lab Guide has this information in Appendix B. Also, the scenario based labs have an example that you can use as a reference:
https://www.myciscocommunity.com/docs/DOC-1525
Marcos
