ASA DMZ Interface setup
johng231
Level 3
Level 3
Hey Everyone,
I was wondering what would be the ideal performance for placing the DMZs on either a physical interface or logical interface. We are using ASA 5550s, the outside is setup on GIG 0/0 and the inside is setup on GIG 1/0 for optimal performance. The ASA 5550 documentation talks about placing the outside and inside on separate PCI bus(s) to achieve maximum performance. They don't mention of having a DMZ on either bus 1 or bus 2. I'm guessing you can place it on the same bus as your inside, since the DMZ talks to the outside for hosting services but you also have a lot of backend applications that needs to communicate to your DMZ.
nisgupta
It all depends upon amount of the traffic. If the traffic between the outside and the dmz interface is more than b/w the inside and dmz then it would be better to put the interface on that bus where the inside interface is located otherwise on put the interface on the outside's interface bus.
If you please let me know the 'show traffic' output of the firewall then I could suggest you where to install(like which bus) the interface.
The key to install the interface is depends upon on the amount of traffic is being passed and it could analyised by looking at the 'show traffic' output of the firewall.
Thanks & Regards
Nishant Gupta
Network Engineer
CCIE (Security) # 20256
Thanks for the information. We are replacing our PIX-535(s) with ASAS 5550 (s). The output below is from one of our PIX-535(s). I plan on having the outside on gig0/0, inside gig 0/1, and the DMZ on gig 1/0. The inside traffic would never traverse GIG 0/0 so I think it makes sense to have it on GIG 0/1. What do you think?
ryefwpixec# show traffic
outside:
received (in 2612362.232 secs):
674063447 packets 1859648235 bytes
1 pkts/sec 1 bytes/sec
transmitted (in 2612362.232 secs):
2290961969 packets 1180576502 bytes
0 pkts/sec 1 bytes/sec
inside:
496137622 packets 3425637339 bytes
0 pkts/sec 1000 bytes/sec
2568127494 packets 1471274881 bytes
1 pkts/sec 0 bytes/sec
FailureNet:
558787 packets 12476048 bytes
89473942 packets 2812506396 bytes
1 pkts/sec 1000 bytes/sec
intf3:
0 packets 0 bytes
0 pkts/sec 0 bytes/sec
0 packets 0 bytes
Ecom-DMZ:
2254395416 packets 4231996422 bytes
2977528782 packets 3794604310 bytes
1000 pkts/sec 1000 bytes/sec
ryefwpixec#
