Different Permissions
Answered Question
Aug 19th, 2009
How can I set Cisco ACS to apply full level 15 access to a user when they connect to a switch, but read only access when they connect to a firewall?
Correct Answer by Erick Delgado about 7 years 9 months ago
This can be done by using command shell authorization.
Please see documentation below.
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml
If you have any question do not hesitate to contact me.
Overall Rating: 5 (1 ratings)
Jatin Katyal Wed, 08/19/2009 - 08:36
  • Cisco Employee,
You can set this by using command authorization.
ACS config:
Create two NDG one for ASA client and one for switch client under network configuration.
Create two different command authorization set for
Switch = permit all
ASA = Deny all
and permit show only
Now, go the user account, scroll down to the Shell Command Authorization Set
Assign a Shell Command Authorization Set on a per Network Device Group Basis
Here you can map NDG with respective command authorization set.
On the ASA:
aaa authorization command LOCAL \\In order to enable command authorization\\
On the switch
aaa new-model
aaa authorization config-commands
aaa authorization commands 0 default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ loca
For more info, please refer this link:
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml#backinfo
Let me know if you face any issue.
JK
