[ACE] - ARP_FAILED with one arm config
Aug 19th, 2009
Hello All,
I'm trying to configure a one arm context but for some reason it does not work. The rservers are marked as ARP_FAILED.
Does anybody have an idea of what wronmg with this config?
I've attached a copy of the configuration to this thread.
Thibault.
litrenta Wed, 08/19/2009 - 09:36
  • Cisco Employee,
what vlan are the rservers in ? the .231 and 232 addresses are not in the range for vlan 1136 (241-254 due to 28 bit mask). one arm config implies servers on the same vlan as the ace.
deephazz02 Wed, 08/19/2009 - 09:53
Thanks for your answer.
The rservers are in a different vlan than the ACE. The idea behind it is that only the traffic that matches the VIP goes to the ACE. I thought it was possible to configure the one-armed ACE this way. Using one vlan for the rservers and the ACE implies 6 ip addresses for the routing only (3 for hsrp and 3 for the ACE).
Thibault.
litrenta Wed, 08/19/2009 - 10:05
  • Cisco Employee,
that should be okay jsut wanted to make sure.
SO are servers reachable through the gateway 10.18.25.243 ? do you have an arp entry for this gateway (show arp on ace)?
litrenta Wed, 08/19/2009 - 10:07
  • Cisco Employee,
if you have an arp entry for the gateway can you ping the servers from the ace ?
what version of ace software ?
deephazz02 Thu, 08/20/2009 - 08:03
I have an arp entry for the gateway and can ping the servers.
IP ADDRESS MAC-ADDRESS Interface Type Encap NextArp(s) Status
10.18.25.241 00.15.c7.0f.a3.80 vlan1136 LEARNED 522 3380 sec up
10.18.25.242 00.0f.f8.12.b5.80 vlan1136 LEARNED 521 3380 sec up
10.18.25.243 00.07.b4.00.88.01 vlan1136 GATEWAY 516 27 sec up
10.18.25.247 00.0b.fc.fe.1b.1c vlan1136 NAT LOCAL _ up
10.18.25.252 00.0a.b8.71.2a.cb vlan1136 LEARNED 523 3380 sec up
10.18.25.253 00.1b.d5.9c.16.b5 vlan1136 INTERFACE LOCAL _ up
10.18.25.254 00.0b.fc.fe.1b.1c vlan1136 ALIAS LOCAL _ up
Thibault.
deephazz02 Mon, 08/24/2009 - 03:03
Ok, it is fixed now now...
Once again it was a bug, I had to delete the rservers and re-create them to fix the issue.
That's realy annoying with the ACE, you spend hours troubleshooting something that eventually happens to be a bug... And in fairness it happens quite often.
I hope this will help someone else.
Thibault.
