WLC Audit Status Mismatch
Answered Question
Aug 19th, 2009
We have two WLC 01 and 02, the WLC01 its the primary and all of AP has WLC01 as primary and WLC02 as secondary.
We've had network issues that have caused WLC01 to lose connectivity (temporarily) - this caused WLC02 to take the Active role, but some users are left without service (others are not affected).
We had to reboot WLC02 to force WLC01 to return to the Active role so all the users recover the service.
The only unusual sign we've noticed is a "Mismatch" Audit Status that shows up in the Configure -> Controllers window in the WCS.
What could be missing?
Correct Answer by Lucien Avramov about 7 years 11 months ago
it will just update the WCS with database with the WLC information. It will not alter your production.
Overall Rating: 5 (1 ratings)
Lucien Avramov Wed, 08/19/2009 - 12:13
  • Red, 2250 points or more
Run a refresh config from controllers on the WCS that should clear the mismatch audit.
Correct Answer
Lucien Avramov Wed, 08/19/2009 - 14:26
arturo_triara Wed, 08/19/2009 - 15:41
I have the WLC02 configuration (show run-config) and I can see that not all interfaces are configured, i mean configuration is missing on WLC02.
***But these interfaces appear reviewing the configuration of the WLC02 through the WCS (Configre->Controllers->WLC02->System->Interfaces)
If I run the refresh will fix the problem?
Lucien Avramov Wed, 08/19/2009 - 15:46
No that will actually delete the data from the WCS.
In that case push a template for the interface to the controller to update those ones with the correct configuration that is on the WCS.
arturo_triara Thu, 08/20/2009 - 09:40
I saw the manual but i can't see the opcion to make a template for the interface.
i only see template for: general, qos, ntp and more but not interface template.
The WCS ver is 4.2.110.0
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
