"env_vars" file on flash - How important?
Aug 19th, 2009
At some point on a 2950-48 switch I have the "env_vars" file was erased. I'm wondering how important to the system it is to have this file. I know the BAUD and BOOT commands are valid for certain tasks but what about MAC_ADDRESS and the SERIAL_NUMBER and all those? Are they just fluff? If I do need them on there is there a command to restore them from the switch ROM?
Peter Paluch Wed, 08/19/2009 - 10:04
  • Cisco Employee,
My personal experience is that if this file is erased, the IOS will recreate it as needed and no damage is done to the switch. A guide for password recovery on Aironet devices even suggests deleting that file when performing the password recovery. So, I would not be concerned too much about it.
Still, it is good to know which settings are stored in that file and to reenter them in the configuration mode if some of them are necessary for your switch to boot up successfully. The list of individual environment variables for the 2950 switch can be found here:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/configuration/guide/swipaddr.html#wp1183705
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/command/reference/bootldr.html#wp1004653
Best regards,
Peter
Lucien Avramov Wed, 08/19/2009 - 10:05
  • Red, 2250 points or more
The env_vars is the boot path.
You can just do the following to recover.
conf t
boot sys flash:
end
wr
This will restore it. Below is an example.
W2S-1.3-c2950#dir
Directory of flash:/
2 -rwx 109 Mar 13 1993 13:38:41 info
163 -rwx 994 Mar 01 1993 00:01:26 old
3 -rwx 2888826 Mar 06 1993 07:17:44 c2950-i6q4l2-mz.121-13.EA1b.bin
165 -rwx 916 Apr 10 1993 01:33:19 vlan.dat
6 -rwx 2774747 Mar 01 1993 00:57:12 c2950-i6q4l2-mz.121-12c.EA1
4 -rwx 39 Mar 01 1993 00:04:47 env_vars
169 -rwx 994 Mar 01 1993 00:00:36 old2
5 -rwx 5 Mar 01 1993 00:04:51 private-config.text
180 -rwx 109 Mar 13 1993 13:42:57 info.ver
8 -rwx 1905 Mar 01 1993 00:04:51 config.text
7741440 bytes total (2068480 bytes free)
W2S-1.3-c2950#del flash:env_vars
Delete filename [env_vars]?
Delete flash:env_vars? [confirm]
W2S-1.3-c2950#dir
7741440 bytes total (2068992 bytes free)
W2S-1.3-c2950#conf t
Enter configuration commands, one per line. End with CNTL/Z.
W2S-1.3-c2950(config)#boot sys flash:c2950-i6q4l2-mz.121-12c.EA1
W2S-1.3-c2950(config)#end
W2S-1.3-c2950#wr
Building configuration...
[OK]
W2S-1.3-c2950#
00:06:03: %SYS-5-CONFIG_I: Configured from console by console
W2S-1.3-c2950#
W2S-1.3-c2950#dir
4 -rwx 39 Mar 01 1993 00:06:01 env_vars
7 -rwx 1905 Mar 01 1993 00:06:05 config.text
8 -rwx 5 Mar 01 1993 00:06:05 private-config.text
W2S-1.3-c2950#
This should resolve your issue.
jbrenesj Wed, 08/19/2009 - 10:34
  • Silver, 250 points or more
It is not necessary to rebuild the env_vars file. It only has a copy of the system specific information that is held in other flash sectors as well. The only information that you have really lost is any setting done by "boot" configuration command. That can be reset by issuing the appropriate boot command.
