08-19-2009 10:49 AM - edited 03-15-2019 07:25 PM
Sorry for the basic questions, but
We have this dial peer created for calls to out DIDs that are originating outside our business and destined for Call Manager:
dial-peer voice 2 voip
description Forward 1xxx to Subscriber
preference 1
destination-pattern 1...
voice-class codec 1
voice-class h323 1
session target ipv4:1.2.1.2
dtmf-relay h245-alphanumeric
fax rate disable
no vad
We are currently receiving the last four digits from the provider.
Where in call manager is this configured to accept these digits from the gateway to be processed?
08-19-2009 12:11 PM
Under h323 GW config
significant digits and inbound CSS
java
if this helps, please rate
08-19-2009 12:22 PM
Is that under "trunk" in call manager?
08-19-2009 01:46 PM
Usually you would have that configured as H323 GW, but you might have it as H225 trunk. Any of those has the config you need.
java
08-20-2009 04:20 AM
Ok,
So, inbound calls will hit the Voice Gateway and depending on how the dial peer is configured, will be passed to call manager and then this traffic will be received by Call Manager per the parameters configured on the "Gateway Configuration" page.
Is this correct?
08-20-2009 05:51 AM
Yes, even if your DPs are correct but the config in CUCM does not allow the inbound css or the right # of significant digits it won't go thru
java
08-20-2009 09:00 AM
But, those parameters are on a different page aren't they?
Calling Seach Space and #s of digits?
It looks like the gateway or trunk is only configured to point to a particular IP Address and allow traffic on a certain port.
Any traffic from this IP Address on this port is configured in Call Manager as voice traffic from the gateway, then it steps through the config from there.
Is this correct?
08-20-2009 09:10 AM
No, inbound css and significant digits are next to each other in H323 GW config.
CUCM only recognizes traffic from IPs that are configured, if you do not bind the H323 traffic to the same IP you used to configure the GW in CUCM it will be rejected.
java
08-20-2009 10:22 AM
Thank you, sorry for the basic questions.
So the communication from the Gateway to CUCM is h323?
Also when using MGCP for call manager to control the gateways, you do not need MGCP locall when call manager is in the same LAN as the gateway, only for remote gateways, isthis correct?
