Layer 2 to Layer 3 Access Layer Migration
Answered Question
We currently have a network at a building with 6506 switches at the distribution and 4503s at the access layer. The 4503s are connected to the 6506 switches via 802.1q trunks. We want to push layer 3 out to the access layer and get rid of the trunks. We want to create a layer 3 link between the switches and create a new VLAN int 10 for the users on the switch. Most users would get moved to this new VLAN and everything should be fine. However we have a number of printers (and other devices) that would need to be migrated over time to this new network so we need to allow the old IPs to work over the switch as well. Would creating an additional (albeit temporary) layer 2 link that exists only for those old IPs take care of this issue? In other words if the current VLAN on the switch is VLAN 200 can we create a layer two link on VLAN 200 between the switches only for legacy IPs while at the same time routing all "new" devices over the layer 3 connection. Keep in mind that the legacy VLAN doesn't only exist on this one switch but others in the network as well.
Correct Answer by Jon Marshall about 7 years 9 months ago
Jim
"If multiple "legacy" vlans are configured on a switch for migration and we decide to trunk all of these vlans everything should still work fine, correct?"
Correct but make sure you only allow the legacy vlans on the trunk link.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 08/19/2009 - 12:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jim
Yes that will work fine. Make sure that the L2 link only allows vlan 200 although if you make it an access port rather than a trunk you don't need to worry about this.
Bear in mind that you will have a lot of suboptimal paths to and from the printer vlan while you migrate but this shouldn't be a problem in a switched network.
Jon
Thanks for the reply Jon. We were planning to make it an access port since only one legacy vlan on this switch needs to work. If multiple "legacy" vlans are configured on a switch for migration and we decide to trunk all of these vlans everything should still work fine, correct? As long as the old vlans and new vlans are different IDs it shouldn't pose any problem?
Correct Answer
Jon Marshall Wed, 08/19/2009 - 12:57
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jim
Jon
