UCCX prompts
Aug 19th, 2009
We have a UCCX server running with CCMExpress. We are wondering if we can play prompts that are not uploaded to UCCX system (the audio files on the hard drive) as we have so many files with total size exceeded the maximum number allowed by the system.
hoanghiep
Overall Rating: 4 (1 ratings)
Jonathan Schulenberg Thu, 08/20/2009 - 05:37
  • Cisco Designated VIP,
    2017 IP Telephony
Until version 8.0, you technically can but it is not supported (and won't be possible in 8.0). Any prompt files that you want to use are supposed to be in the Prompt Repository.
I must say I'm a little curious what you have designed that requires that many WAV files; however, if a bunch of them are verbiage, you may want to look at using an ASR server to speak the verbiage instead where it makes sense. That would cut down on the volume.
